Plasma Cutter Shelf/Stand, 16in on center out of 16ga steel Tools
Simple plasma cutter shelf to get it off the ground. I cut it out of 16ga steel and bent everything by hand then spot welded. It is suprisingly sturdy. Mounting holes are 16in on center.
You may remix, tweak, and build upon this work non-commercially, and although your new works must also acknowledge Cary and be non-commercial, you don’t have to license your derivative works on the same terms.
407
shelf plasma cutter shelf plasma cutter stand razorweld shelf razorcut shelf razorweld stand razorcut stand
  • Plasma shelf 2.0.dxf
  • Plasma shelf 2.0.nc
  • Cary (OP) - 2 years ago
    If using that NC file directly, please ignore that rectangular piece below. Only the single top piece is required.
  • kirk - 2 years ago
    Question: What are the holes on the front used for?
    I just added them for miscellaneous tools such as screw drivers or Allen keys needed remove my torch from the machine to replace consumables
  • wyatt grill - 2 years ago
    Beautiful just beautiful!
  • Steve Bubacz - 2 years ago
    and I was gonna make one by hand!
