Plenum Plate 5.2 Dodge Magnum Automotive
If you have a 5.2 0r 5.9 Dodge Magnum engine that is older I'm sure you are familiar with the plenum gasket failure on the bottom of the intake manifold. I made a solid piece without the bolt holes because I TIG welded mine onto the bottom of the plenum. The holes are for someone who may want to make a thicker plate out of some thicker aluminum and bolt it on with a new gasket. It should measure 16.87in (16 7/8in) from the top left corner to the bottom right. Happy Cutting
You may remix, tweak, and build upon this work non-commercially, and although your new works must also acknowledge Jack Deacon and be non-commercial, you don’t have to license your derivative works on the same terms.
6 years ago
98
  • Plenum Plate.dxf
  • Jack Deacon (OP) - 6 years ago
    My RAM is an 01.
  • Michael Butler - 5 years ago
    I own 2 5.2 and 2 3.9 dakotas. Planning on rebuilding one of each. Damn 3.9 is leaking at the plenum. Thanks for this!
