Porta-band saw table Tools
This was made to fit the Bauer (harbor freight brand) porta-band saw. I have attached the top to my saw but have not yet done so with the legs. The design is pretty straight forward.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit James Jackson for the original creation.
525
  • Porta band saw table top.dxf
  • Porta band saw leg.dxf
  • Leon Corley - 5 years ago
    Are the slots defining fold lines? What's the tilted square inside the leg drawing? What thickness stock did you use? Thanks, Leon
  • James Jackson (OP) - 5 years ago
    the tilted section is only the text box. not sure why it shows up like this but in fusion, it doesnt cut. If needed, I can upload the standard leg dxf. Nothing on this file is tied to a certain thickness of material. I would suggest 3/16" or thicker. And yes the lines are to make bending easier.
    chase - 5 years ago
    got any pictures of it you can share with us?
