Portable bandsaw stand Tools
Modified House of Chop design. 1/8 for the base, 1/4 for the top. Top designed for my HF saw so will need to be modified for other saws but the base should work for any saw.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Bob Dobinson for the original creation.
307
  • Portaband base generic.dxf
  • Portaband top - Harbor Freight.dxf
  • Kristian Ruess - 3 years ago
    what are the measurements for this?
  • Bob Dobinson (OP) - 3 years ago
    Rough dimensions if I remember correctly - Top is 18x13, base is 14x11. If you load it up in Fusion 360 you can check the measurements
  • Mike Blake - 3 years ago
    I put this together and it works pretty good, but Im curious as to how everyone attached the saw to the table? right now mine is just clamped on, would like to mount it better
    I drilled/countersunk holes and mounted it to where the guide plate attaches. I did need a shim to get the correct thickness.
  • scott - 1 year ago
    What saw are you using? If you using the bauer bandsaw from HF , what is the bolt pattern for mounting?
