This is a cut and fold firepit. I tack welded all the sides, and legs after folding. Tabletop legs, and Propane tank mounts fold and bolt on. Use wood, or the burner of your choice, this one is brass fittings with homemade jets in a crossfire configuration. You can tap the center hole with a 1/2 npt tap to thread the fitting into the tray. It is very stable on the ground, a table top, or flanged onto a propane tank. Grooves in the sides hold skewers nicely.
112
Firepit Fire Pit Propane
