Razorweld J45H Alignment boot Tools
I printed this to slip on the nozzle of the J45H torch. the crosshairs make it very easy to find center of the torch when aligning to the sheet. it has about .030" clearance from the material, so with the THC working, I have yet to have an issue with it making contact and does a great job keeping water and sparks going down into the water bed. I printed this out of ABS and have about 20 hours worth of cutting with it with no problems. .STL can be found at https://www.thingiverse.com/thing:4934650
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Luke for the original creation.
52
splash boot alignment
