Razorweld J45H holder Tools
This is a gusset for the J45H torch to reduce the stress on the z-axis. Zip ties secure the torch and cord while in use. Bend the tabs and transfer punch the holes on the OEM torch mount. I used 6-32 screws.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Luke for the original creation.
371
Torch razorweld j45h
  • Razorweld J45H torch holder.nc
  • david warsackAllcutup - 3 years ago
    Is the J45H the x45 torch ? For razorweld ?
    Luke (OP) - 3 years ago
    you are correct
    Where do I get the shield for the trigger download for the torch ?
  • David Downs - 3 years ago
    Is it possible to just get the dxf. I don't know how to use an nc program. I'm using fusion 360 and mach 3 with a "legacy" machine. No z axis.
    i dont see where i can edit this post, but i still have the dxf so i could send it to you.
  • scott - 2 years ago
    Thanks Luke, works great
