Razorweld J45H Torch holder-Printed Tools
This is 3D printed torch holder for the J45H torch for the Razorweld cutter. I 3D scanned the holder and then created a mounting system that will attach the the Z-axis using (3) 10-32 screws. I am not giving the locating hole locations on the table because my gantry is 1 1/4" elevated from stock height to accommodate more clearance so you will have to figure out a location that works best for you to drill the holes to mount. The fit-up is very tight on the torch, you need to rock the holding onto the torch from back to front (look at cross section picture). I made it so that the holder clamps the torch in place on its own, the zip tie is strictly for safety. allows full access to the tip and nozzle without having to unclamp from table so you do not loose position when changing consumables. printed 25% infill with 5 shells PLA. https://www.thingiverse.com/thing:5378153
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Luke for the original creation.
48
J45H Razorweld torch
  • Tim Bledsoe - 2 years ago
    Man that is very nice Langmuir should be contacting you to purchase these for there machine and put them into the package. Great Jog!!
    Luke (OP) - 2 years ago
    thanks! it is something i have wanted to do for some time and i am very happy with how it works.
  • ryan major - 1 year ago
    IS there supposed to be an STL file to download? All I see are pictures. This looks like a really nice mount that I would love to print.
    Luke (OP) - 1 year ago
    in the text of the description is the link to the .stl. or you can search thingiverse for the same title since that is where i uploaded the file. you cannot upload .stl files on this site
