This Razor Rack will get your plasma torch of the ground and up where you can actually get to it. The risers use the existing stanchion bolts, and allows for full motion of the carriage underneath. Because of the length, the top is in 2 parts that either need to be welded together, or indexed and cut as one piece. Riser height might need adjustment based on your attached external filters or regulator. TAP file is for Firecontrol v20.4 and may need to be converted for v20.5. Enjoy - RockMountainFab
You may remix, tweak, and build upon this work non-commercially, as long as you credit Rock Mountain Fabrication and license your creations under the identical terms.
182
RazorRack Razor Rack razorrack razor rack RMF-RazorRack
  • CFP RazorRackTop-PT1.dxf
  • CFP RazorRackTop-PT2.dxf
  • CFP RazorRackRiser.dxf
  • CFP RazorRackRiser.tap
  • CFP RazorRackTop-PT1.tap
  • CFP RazorRackTop-PT2.tap
  • Rock Mountain Fabrication (OP) - 4 years ago
    This is designed for the Crossfire Pro.
  • Portagee Customs - 4 years ago
    What gauge steel did you use. Thanks for the awesome plans. This is the best/coolest solution I've seen.
    This was 12 guage hot rolled.
  • Jim Maltby - 4 years ago
    Cool! Thanks!
  • Jay Hitchcock - 4 years ago
    Did you have to get longer DIV cords? Mine won't reach.
  • damon - 4 years ago
    this is awesome can you please share the file?
    To keep the control box in the original location, you will have to extend the THC and Torch On/Off cables. I cut and spliced in 8 feet on mine without issue.
