sheet alignment tool Tools
this is my version for sheet alignment. I simply hang it over the Y axis rail, I slide my work piece up to it, then remove it. making the sheet parallel to the Y axis. tach weld the 2 pieces together and it stabilize the piece while loading a sheet. I used .250 material.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit jesse haskins for the original creation.
653
  • table sheet alignment tool.dxf
  • joe juhl - 5 years ago
    Not a hundred percent sure how this works. Could you post a picture of it in use? Thanks. Forgive my ignorance
    David - 5 years ago
    I think you turn the small piece perpendicular to the large piece and insert the slots to each other. Then tack weld. When you place a sheet of stock on the water table, hang the new made bracket over the y axis and slide the sheet up to the edge of the bracket on one end of the y axis. then repeat on other end of y axis. Now your sheet is perfectly aligned with the y axis … great idea
    jesse haskins (OP) - 5 years ago
    You are correct, except I cut a few of them. Leave 1 on each end of the sheet till I'm ready to cut
  • Michael Olsen - 5 years ago
    This is a great tool. Thanks for sharing this design.
  • Michael Baca - 5 years ago
    Thanks
  • Brian - 5 years ago
    Can anyone share a pic of this?
  • DogCreekCustoms - 4 years ago
    I don't think this will work with my Jd2 table, but nice concept.
  • Brandon Y. - 4 years ago
    This came in clutch for my project! Thank you!
  • Chris Wiegman - 3 years ago
    Thanks for this! After a successful project I feel like it unlocks a new feature of the Cross Fire! In my case I was tiling the design, cut several 60" x2" steel flats, passed through the machine, align and cut what I could!
  • Robbie Griffith - 1 year ago
    thank you sir
