Shelf / Coat Rack Project Home & Garden
You can create any shelf you want with the blank design with your own graphics and text or use the cowboy design. Bend the screw mount tabs along the top edge in, then each end bends in 90 degrees and finally bend the coat hooks up in a curve. Add a top wooden shelf that is 25.75" by 6.75" and you will have .75" overhang on both of the sides and the front. The SHELF3 design does not need the hooks curved, instead it uses hooks like these from AMAZON - https://www.amazon.com/Amazon-Basics-Mounted-Contemporary-Single/dp/B07PZNVLD4/ref=sr_1_1_sspa?crid=349UCFYPONYYO&keywords=coat+hook&qid=1646175783&sprefix=coat+hook%2Caps%2C419&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEyUjlZRkFUWE9TUzdEJmVuY3J5cHRlZElkPUEwODIzNjMxMzFOOUpYNVlQNUxMMiZlbmNyeXB0ZWRBZElkPUEwMjEzNzc0MzkxUEFWVUlXV1c1QiZ3aWRnZXROYW1lPXNwX2F0ZiZhY3Rpb249Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
663
shelf coat rack wall cowboy
  • Shelf1.dxf
  • Shelf2.dxf
  • Shelf3.dxf
  • Dennis McLeod - 4 years ago
    Nice!
  • Jordan - 3 years ago
    my download came through and it looks like it is 18inches wide. Is that how big you recommend it to be? So much detail.
  • Michael D Sirmons Jr - 2 years ago
    Thanks!
  • Stephanie Bregher - 2 years ago
    Thanks much for sharing!
  • Tim Meacham - 1 year ago
    Thanks
