Shooting targets Outdoor
4 and 6" targets need AR500 1/4" plate. hooks and brackets are 1/4" hot roll steel. Takes 2 lengths 1" emt conduit cut 4 pieces 40" for legs leaves 80" for top rail. Very portable for outdoor shooting practice.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit David Frey for the original creation.
912
  • 4 inch target.dxf
  • 6 inch target.dxf
  • hoooks and brackets.dxf
  • Trey Parrish - 5 years ago
    Having problems with cutting the target. When I simulate it in autocad it's fine, but when I run it in firecontrol it tries to cut the two holes practically on top of each other. Any help is appreciated.
  • David Frey (OP) - 5 years ago
    there are five sheetcam layers. top bracket, holes, hooks, 4 in target, 6 in target. 5 operations. you can cut one or all by checking or unchecking layers and operations. Not sure why firecontrol is trying to cut holes on top of each other. I have original cf and use mach 3. Have cut this multiple times with no issues.
  • Robert McBrien - 9 months ago
    can:t cut on fire control
