Shopping cart key(quarter) and bottle opener Tools
Combination shopping cart key for carts that take a quarter sized coin and bottle opener. I have tested this on Aldi shopping carts and it works well. Cut from 14 ga steel at 35 amps.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit David Saul for the original creation.
1132
  • Shopping cart opener.svg
  • Shopping cart opener.tap
  • mattfranklin - 3 years ago
    It worked pretty well for my first cut. I used an old circular saw blade for my raw material. The resulting piece was perfectly functional. It did leave a few marks where the pierces were done, mostly because I just took the default settings. However, it does offer a couple of adjustments to those defaults -- cleverly it asks you what you want to change as you are downloading. Would recommend to a friend.
  • Robert Kibby - 3 years ago
    whats a Tap file? cant load it into Fusion
