Slag scooper i made, cut using powermax 45xp fine cut nozzle, 45 amp, 16 gauge stainless steel. Unfortunately lost the svg when I quit fusion360, but maybe this file will help someone. Be warned: it's really bad, the holes cut in a terrible order, for some reason the outer edge is cut halfway through cutting the inner holes, which really messed up the cut for me, but it does still work for scooping slag. Head is 2.5 inches by default. High difficulty solely for this fact of tiny holes and bad file design. You can make it work, but it might not come out as it looks.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Bryan Robbins for the original creation.
18
Advanced
slag scooper foundry metalworking
  • slag scooper 16 ga stainless fine cut.nc
  • Bryan Robbins (OP) - 1 year ago
    Also it's intended to be bent 90* at the point where the circle overlaps with the rectangle, the holes reduce the strength of that line some so it's not as hard as bending 2.5 inch wide 16 ga stainless steel.
