This handle is for lifting the slat assembly out of the water tray on the CrossFire. See the instructions in the FORUM under "CrossFire/tips and tricks/slat assembly and water tray maintenance" http://forum.langmuirsystems.com/t/slat-assembly-and-water-tray-maintenance/2087
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Dave Ceneskie for the original creation.
6 years ago
228
Slat lifter
  • Slat lifter.dxf
  • Millar Farewell - 5 years ago
    Dave, this is a great tool that will defiantly help remove the slates from my water table.
  • Millar Farewell - 4 years ago
    Hello Dave, after 8 months of use I can only say THANK YOU! My slat lifters get a lot of work as I use my crossfire outside and remove the slats to clean the water table after every use.
