Smokeless Firepit Home & Garden
Similar to the "Solo Stove" Trademark Firepit. Burns cleanly and nearly smoke free. Most of this is 16 Ga steel, with the actual fire rack as 11 Ga. steel. Let me know if you need more info.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Robert Barber for the original creation.
760
Advanced
Fire Pit Smokeless hexagon
  • Standoff.DXF
  • Flat pattern - Burn Tray.DXF
  • Spacer.DXF
  • Inner Wall Top Flange.DXF
  • Flat pattern - Inner Side.DXF
  • Inner Bottom.DXF
  • Outer Side.DXF
  • Outer Bottom.DXF
  • Sebastián - 3 years ago
    Muchas gracias por compartir. Tiene buena pinta.
  • Kent Carbaugh - 3 years ago
    Is the ash pan the burn rack, without the holes?
    Robert Barber (OP) - 2 years ago
    yes.
    Roy hughes - 1 year ago
    Why can’t I download it to sheet cam?
    Kenny James - 1 year ago
    you have to take it out of the zip files there is the svg version in the zip files after you double click it
    Ok I’ll try it and see thank you
  • Frank - 2 years ago
    Do you have a larger version designed?
    no.
  • Eric - 2 years ago
    How much material does it take to make this?
  • Tim Heimerl - 2 years ago
    Is there a chance I could get the cad data?
    Robert Barber (OP) - 1 year ago
    Yes. But I need to know what form of cad you would like it in. Original work was in SolidWorks, but I can save it in many other forms.
    MidwesterneRR - 1 month ago
    Hey Robert, any chance I could get the solidworks? Midwesternerr@gmail.com
  • Roy hughes - 1 year ago
    Can you email it to me I can’t download it
    Sorry for the delay. I don't visit this site often. Yes, but I need to know what form you need it in, as well as an email address.
    Svg and dxf roel_hughes@yahoo.com thank you
  • Keith Judy - 4 months ago
    So, how has it held up, being 16 ga and all, (except for the fire rack)
