Spare tire mounts Automotive
These are standard PCDs for trailer wheels. I needed to make a spare tire mount for a trailer I built so I made 3 of the most common PCD patterns for trailers. The holes are just over 1/2" so you can insert the bolts and weld them in place. For the larger 9/16 stud wheels, you will need to drill them larger or just modify my templates. I used 3/16 plate for these and simply welded a 2" x 1/8" wall HSS tube to the back and then welded on the trailer.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Paul Badgley for the original creation.
3 months ago
33
Spare tire mount Trailer 4x4 5x4.5 6x5.5
  • 5x4.5 wheel mount.nc
  • 6x5.5 wheel mount.nc
  • 4x4 wheel mount.nc
