Spider man mask cleaned up Art
Cleaned up some areas that were to tight to cut so now its cut ready
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Knick for the original creation.
418
Spiderman
  • Spiderman mask final.nc
  • Clinton Long - 2 years ago
    Came out pretty good, except every cut needed to be bent and pulled because the loop didn't complete. I just dealt with that with a different drawing and figured out the fusion 360 settings that keep it from happening. Make sure lead-out is selected in the 2D Profile window and the Linking Tab. Also make sure Finishing Overlap is set to whatever your kerf width is. Those two settings will make sure each of the cutout loops actually connect and the pieces come right out.
