Tank Clamp will not cut Tools
It's a tank clamp that I cannot get Fusion 360 to produce a G-code file for
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Brian Ricklefs for the original creation.
36
  • Tank Clamp WONT CUT.dxf
  • Brian Ricklefs (OP) - 5 years ago
    I can't get this to cut somebody tell what is wrong with the part. Thanks
  • Michael Butler - 5 years ago
    You have some trimming on the top and bottom that you need to do. I also had to change the pierce clearance to .01. It may not be the correct way, but I got it to work. I can email you the G code, the file I made is for 39 ipm. you were also not on the x and y plane, so I had to play with that some too.
