Titan Lift Plate 1/4 Steel Tabs & Brackets
DXF File for lifting brackets for your Titan 25T. Simple part to add to your Titan assembly to allow easy lifting and moving. Material: 1/4" mild steel. Two will be require for the lifting and moving process. Requires 2 High-Strength Grade 8 Steel Hex Head Screw, 5/16"-18 Thread Size, 1-3/4" Long (https://www.mcmaster.com/catalog/130/3595/90409A126) as well as 2 5/16-18 Serrated Flange hex nut will be needed for the lift plate.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Johnny for the original creation.
178
Titan Titanliftplate Lift Plate Press Break
  • TITAN LIFT PLATE - Johnny.dxf
  • Brandon - 11 months ago
    Is there a larger photo of this connected? We cut them, but I do not have any hole patterns that match what is shown
