to the moon Art
the moon
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit naudydave for the original creation.
794
moon
  • TO THE MOON.nc
  • Sam Lindh - 4 years ago
    Is the .dxf available for this?
  • robertzucker1@gmail.com - 4 years ago
    file wont load need a dxf or svg
  • Mat - 4 years ago
    Great file thanks
  • Mat - 4 years ago
    Hey i used your cut ready file and your settings. Your imp At 200 Was way faster than what i use. I figured I’d try it . Well I’ve been cutting way too slow my IMP i was set at 90 35 Amp .So I’m using your settings for now on for 16/ 14 gauge I’m curious what are your settings for 1/8
    naudydave (OP) - 4 years ago
    so i have a hypertherm 85. with it on 85 amps i can cut 1.4 at 200ipm. when i turn it to like 45amps i cut 1/8 at like 70 or so. i also have green 1050 fluid in the water table which makes a big difference.
  • John Godwin - 2 years ago
    Thank you I am going to try to make a run at this
