Torch Shield for Xfire Tools
I was getting some water splash onto my torch handle, right on the trigger, which is not water proof or Water resistant. I decided to cut this out of alum (had some laying around) to mitigate this issue (since water and elect switch = headache sooner than later) Simple cut, alum settings of 120/min at 20 amps with a 0.1 pierce delay worked great. Holes are a little messy but can be cleaned up with a drill bit or dropping the amps down some more (maybe 15?). 30* bends on each side (or as you see fit) with a bench bender and the attachment tab was done with hand held bend pliers. I put a little bit of angle on it too so that if I do get water droplets inside it will act as a gutter. Length is 6.5 inch long.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit JB Lefebvre for the original creation.
6 years ago
1580
  • Torch Shield.dxf
  • Scott Murray - 6 years ago
    when I loaded the dfx all I got was a rectangle and two circles that were not inside it.
  • Luke Erwin - 6 years ago
    same
  • Wade Starkenburg - 6 years ago
    Same
  • ShaunyShaun - 6 years ago
    same
  • JB Lefebvre (OP) - 6 years ago
    unfortunately the design is created with sheetmetal workspace, so the sketch that I was able to export was of the hole location and the rectangle...thought the DXF would have more than just the sketch...at any rate, the holes are 1.5" apart, do a rectangle that contains those and then use sheetmetal workbench to create the sides to your dimension that best fits your torch. Until we can share F360 files...
    Nick - 6 years ago
    Use the Unfold command in the sheetmetal workspace - then create a sketch, project the unfolded pattern to the sketch and right click the sketch on the tree to "save as DXF" There is a NYCNC video #FF94 that shows how to do it. If you share the F360 file with me I can help too. https://youtu.be/nEjFMYNGY4g
  • Richard Hamilton JR - 6 years ago
    just download the FUSION 360 APP makes share a POC PIECE OF CAKE
  • Williammaddox - 6 years ago
    i will need this thanks
  • kevin jackson - 1 year ago
    gonna try this one now.
