This filter does not come with a bracket so I made one out of 12 gauge steel. I am not sure if the DXF file came through correctly but I included a capture of the image with dimensions. The fitting is 1/2" so the hole is 0.95 inches which accommodates the outer part of the fitting so you will need to install the bracket and then the fittings. Obviously it could be shortened in the front but the holes are as close to the wall as I felt comfortable. It has about 1/8 inch from the inside of the bracket to the back of the housing of the filter. If the DXF came through it has two other brackets for mount a PneumaticPlus SAR400T-N04BG Compressed Air Regulator 1/2" NPT, T-Handle, so the pipes line up properly. The third bracket is a simple support bracket for supporting the line for other devices (valves, filters, hose line).
45
Filter bracket air compressor dessicant desicant
Jim Bibler (OP) - 2 years ago
