Truncated icosahedron - aka "Soccer Ball" Art
Single piece ball with bend reliefs. Cut, bend and weld.
Creative Commons - Attribution - Share Alike
You may remix, tweak, and build upon this work even for commercial purposes, as long as you credit Randall Glenn and license your new creations under the identical terms.
215
  • Truncated icosahedron.dxf
  • Truncated icosahedron.svg
  • EJ Ciramella - 3 years ago
    Not sure what's going on with this dxf, but it 1) loads HUGE in fusion and 2) I can no longer select/delete it.
  • Randall Glenn (OP) - 3 years ago
    Probably scaling issue. The file was created in Autodesk 123D Design using millimeters. Odd you can't select or delete it once in fusion. The download also has a SVG file.
