I don't like drawing a circle every time I just want to make a hole. This makes removes the step of drawing a circle in Fusion360 or other CAD software, and saving the DXF. Just open the Circles.DXF file in SheetCam, then select the circle size you want and don't forget to select the appropriate "Contour method" Because SheetCam does not import layer names with decimal points, a 1/2" hole is labeled as "_5_DIAM" and 1/4" hole is "_25_DIAM" and so on. All the hole sizes are listed in decimal inches. I also included some oversized holes to give clearance for hole taper.
507
Drill press holes Sheetcam
