Drawn with 3/16" plate for 2" angle
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Chuck Jolly for the original creation.
271
  • VEE BLOCK.dxf
  • Derek G. - 4 years ago
    I like it. Very simple and straight forward. What software are you using to design? I'm thinking of something very shallow to hold a pipe on the CNC table to cut holes or slots as desired. I know you can cut small holes on the table using THC.
    Chuck Jolly (OP) - 4 years ago
    I use QCAD. It’s free and not too hard to use. Not a bad idea. Maybe you could use something with vertical slots that would slide on to the crossfire table slats
  • Chris Illar - 3 years ago
    what gauge steel did you use?
