Wall Art - Deer Head Art
23.5in x 29.5in deer head wall art. If cutting on a Pro, remember to rotate 90 degrees. Yes, I know I spelled deer wrong in the file name. Settings are for 14ga MS, cause that's what I had. I cut with 37amps and it came out beautiful. The file has mounting hardware nested in the horns that needs to be bent at the cut lines and welded on. Stands 1/4in off the wall. Hooks were welded just above the horns in the center. Smaller standoffs were welded in the bottom left and right sides.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Nathan for the original creation.
545
art deer
  • DearHeadWallMount.nc
  • Travis Reynolds - 3 years ago
    Thank you!
  • Brett Poling - 3 years ago
    Thx Pretty Cool!
  • Jesse Burnsworth - 2 years ago
    thanks
  • Glenn Petti - 2 years ago
    Thank You
