welding sign
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Custom Ironworks for the original creation.
532
welding welder
  • WELDING SIGN 2.svg
  • Larry Bjustrom - 1 year ago
    thanks
  • craig welch - 1 year ago
    thanks
    thanks
  • Jason A Gunning - 1 year ago
    HAVING ISSUES . Feature flags: inspection-in-pim (off) setup-sheet-viewer Debug: Initialization elapsed time: 0 ms Debug: Writing ironjob to C:\Users\drome\AppData\Local\Temp\Fusion360CAM\2920-1\operation3.ironjob Debug: Writing jobfile to C:\Users\drome\AppData\Local\Temp\Fusion360CAM\2920-1\operation3.hsm-job Debug: Using CAM kernel from: C:\Users\drome\AppData\Local\Autodesk\webdeploy\production\9852aa66f5af6660db76d8087c75a7da16ce322c\Applications\CAM360\camkernel.exe Warning: One or more passes were discarded due to linking constraints. Debug: Autodesk dcamcomponents 1.226.3 pm12859 Autodesk CAM Kernel 3.158.1 (1297e41d) x64 STABLE vs2022 1297e41de3aaf59918db92aaf19c1a1ff5dc4663 2023/12/01 07:00 Warning: multiple contours have collapsed, unable cut entire path. Warning: One or more passes were discarded due to linking constraints. Debug: Total processing time: 38718 ms Debug: Total elapsed time: 39846 ms Generation completed with 1 warning(s) in 39.8s.
  • Ginnie Lynn Toney - 10 months ago
    thanks
  • jim deckler - 8 months ago
    thank you
