World Map Compass Clock Home & Garden
Here is a clock designed to be cut out 18" (45.72 cm) wide. The 6" (15.24 cm)disk is painted a contrasting color placed behind the map layer and hides the clock mechanism. The center hole is 7/16" to allow for a 3/8" threaded shaft and if you resize the clock make sure you resize this hole to allow for the right size. Almost any clock kit will work, designed to be used with this kit from Amazon... https://www.amazon.com/EMOON-Torque-Movement-Mechanism-Quartz/dp/B083QZSZ75/ref=sr_1_4_sspa?crid=1QPKE67IK7P4V&dib=eyJ2IjoiMSJ9.X1eOP9mqfBvCAETiEdAdX4bM64kE9tMhfFtmuZ0K-i9wyScQcdGrM63WeEOGRcitAtxyYHdxL2vScilw_xoPTB8f14hUX1UUal_KVXOhG1YX0_AzIiuEQcUYtViSfbvx0Tfnw8slUI8-y_lbDIPiGqrWwdBilKCrnf2MvgVySiiVCJF73UTVotvbeZZ-bmqmOpDF8tg4xdLiAGrFt0N3umc8yqHieZ8jM18BKTY6qWQfbTGroOTJxnG4FVTKLKnouiE3Wn91-TDzyO_Pv_wD_V9Q_deWWUeB19AW_yWE7to.9u4b8ryLQ3NxLYk2GzEgpYYoSkDcD25oa5LYPEe5D1s&dib_tag=se&keywords=clock%2Bmechanism&qid=1735575252&sprefix=clock%2Caps%2C294&sr=8-4-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1
91
Wall clock map world compass
  • World Map Clock.dxf
  • World Map Clock Center.dxf
  • World Map Clock.svg
  • World Map Clock Center.svg
