X Axis brace roller Tabs & Brackets
OK, this is my 3rd attempt to upload this on here so I hope it works this time, if not, I give up. Hope it works now.
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit Chad Schulz for the original creation.
348
  • Gantry X Axis support v4.dxf
  • Matthew T Mead - 4 years ago
    I really like this bracket as I found myself accidentally leaning a bit on my X gantry. Thanks for sharing! Did you use something in the neighborhood of 3/16" thick metal? Any suggestions on where to get wheel (or do I see 2 wheels stacked) to fit your design? Thanks!
    Chad Schulz (OP) - 4 years ago
    I used a couple wheels from a set of castors I got at Canadian Tire. And yes it is 3/16"
  • Chuck Wolfe - 3 years ago
    Is the drawing to size or does it have to be scaled down. It doesn't fit the work area for the small Crossfire. It is awesome though
