Just a quick build, these supplementary and adjustable X-axis limit brackets are just what I needed on my PM935 milling machine for such things gear-cutting, face-milling, etc. Cut from 16g steel sheet and bent, they are quick to install, setup and remove, the little bent tang, sits in the t-slot and eliminates any rotation.
26
machine shop milling machine shop fixtures
  • Xstop.dxf
