Xmas 2022 24x16 boy and santa panel example Langmuir Forums TinWhisperer Example Live Stream From Twitch Home & Garden
You may distribute, remix, tweak, and build upon this work, even commercially, as long as you credit TinWhisperer for the original creation.
328
christmas xmas forum tinwhisperer santa
  • Xmas santa boy.dxf
  • xmas santa boy.nc
  • TinWhisperer (OP) - 2 years ago
    https://www.twitch.tv/videos/1658041316 Twitch live stream of making this. https://forum.langmuirsystems.com/t/twitch-live-stream-cad-cam/24762/87 Langmuir forum post Get the NC file here the one above is set to a .001 sec delay https://www.youtube.com/channel/UCWKxDXyVw52g8tQQDpZvlcg I also have I YouTube Channel If you have something specific you want to see walked through let me know .
    stan softich - 2 years ago
    good after noon love the design's but on this one issue with firring and torch height control . crossfire xr 14 gage steal , some of your programs work flaw less ,
    I have in set for .06 cut height and .015 pierce height in the program? i wonder what the issue could be? Could you post a picture of your finished piece on the forum site? I'd love to see them. ( the link is on the first comment) I am glad your happy with some of the programs!
    issue on the program is it fires the first cut path , then dry fires the next 3 torch v reads 210v but no fire ,on the longer lines the face torch starts out normal then lifts up accost the cut approx. 1-inch burned the plate . spent about 4 hrs i did remove and down load 3 times , vm checking machine and grounds , gave up loaded 4 more different programs ran flawless , and will attempt some pictures
    Ok its is my fault the pierce delay was set to .001 second?! I'll upload a new NC file to the forums https://forum.langmuirsystems.com/t/twitch-live-stream-cad-cam/24762/87 Thank you for pointing it out.
    well it did work .thanks . ya i know i really need to learn to read g codes
    Great! post some pictures of the finish results, I have not cut one yet. Come over the the forum. There is a lot of information on G code to learn over there. https://forum.langmuirsystems.com/
  • Patty Stoltz - 8 months ago
    Excited to try this. Thanks for sharing
